hm musste grad für nhl 09 nen update runterladen, weiß einer näheres dazu? also was verändert wurde?
Weiss ich auch nciht, aber ich hab festegestellt das es mehr strafen gibt...habe osnst pro spiel ein oder zwei und dnach dem update 7!
Here are the release notes for the second patch.
Exploit fixes:
-Prevent players from entering games with attributes that are raised beyond the level they can reach with the card they are entitled to have. Players who have elevated their attributes this way should reset their character by changing the type and reassigning their points.
-Limit the size of human goalies in OTP/EASHL games to 6'4" (NOTE: it will still allow them to be set larger, but the actual height in game will not go above the new limit).
-Fixed some problems that could cause the game to hang or go out of sync when pausing.
- Prevent use of LB to get up instantly after being knocked over.
-Reduce accuracy of shooting while using vision control to skate backwards.
-Prevent high, accurate slap shots from in close to the net.
Other changes:
-Reduced the ease of beating the goalie on the short side.
-Decrease the tendency of the goalies to use a desperation save unnecessarily.
-Strict calling of interference, though you can still clear players directly in front of the net without getting called for interference.
-Added stick lift to Classic controls using LB+X (XBox) /L1+ Square(PS3). It is also on R3 (press Right Stick).
-Fixed shot targeting using the Always Up control when skating down ice.
-Added new NHL rule to locate face- offs in the attacking zone to start a powerplay.
- Prevent CPU players from getting delay of game penalties frequently while clearing the puck from their zone.
- Prevent puck from being poke checked away from the goalie when he has it covered under his glove.
-Reduced the amount of time it takes to get control of the last man back, holding RT(Xbox)/ R2(PS3)
-Reduced the amount of time it takes to get control of the goalie, holding LB+A (Xbox)/L1+X (PS3)
-Reduce the range of heights on randomly generated CPU players, including goalies.
-Eliminate the ability to accelerate and maintain high speed which stick lifting.
-More penalties for high sticking when stick lifts are done from behind the opponent.
-Made the colours of the OTP/EASHL indicators more distinct (yellow and orange).
-Made face-off outcomes slightly more random and slightly less dependent on attributes.
-Added assistance to prevent one-timer and shot attempts from leading to accidental hits and interference penalties.
-Goalie tuning to increase goal-scoring a bit to compensate for taking away the easy short-side high goals.
-Improve hit stat tracking to not count all of the small bumps in front of the net.
-Increased injuries caused by CPU teams.
-Prevent puck from being launched with very high speed following a hit.
-AI tuning for superstar. The Aggression slider now affects how intense the CPU team is on that difficulty level.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »AlterEgoRocker« (4. März 2009, 18:26)
HALLO!!!
ich hab mal eine blöde Frage:´
ich hab schon einige 100 Spiele gemacht auf NHL09 gespielt, aber ich
hab es noch nicht geschafft, einen One-Timer zusammen zu bringen!
kann mir bitte jemand helfen???
danke
wann kommen eigentlich kader updates????
Habe ein Problem, beim Bully...Ich gewinne 1-2 stck pro Spiel und das mit glück, weil ich wie wild rum am zucken bin am Pad...aber ich weiss nicht wirklich wo ich den Bully spiele..
hi wenn jemand mal lust auf nen online game hat der kann mich gerne adden gamertag:sebi1985xx
Original von Pinturicchio
Das Bully machst du mit dem rechten Analogstick (damit steuerst du ja allgemein auch den Schläger grob gesagt). Dies trifft aber, so denke ich zumindest, nur auf die neue Steuerungsvariante zu. Beider klassischen wird das Bully woanders gehen.
Du musst wenn der Schiri den Puck fallen lässt den rechten Stick kurz nach unten bewegen. Gegen den Computer gewinnt man eigentlich immer Bully, bei den andreren kommt es auch auf die Bully Skills drauf an.
Danke euch 2
Moin!
Das Spiel ist ja nun schon ne ganze Weile draußen. ich hab überlegt es mir zuzulegen. Ihr habt ja jetzt bereits ausgiebig gezockt. Könnt ihr es weiterempfehlen?
Mein Problem ist: es kostet immernoch 60€...
Also ich finds echt super gelungen. Die Steuerung macht ungemein viel Spaß und online 6 vs 6 bockt auch voll. Offline hab ich das Spiel leider noch nicht gespielt (außer gegen paar Kumpels vor einer Konsole). Aber Grafik, Steuerung, Spielmodi, Anzahl originaler Teams, usw... is echt alles super! Allerdings würde ich mittlerweile noch ein bisschen warten, wird bestimmt bald billiger!
Ja werd ich wohl auch machen. Und die Demo schau ich mir mal an.
Sind die aktuellen DEL-Kader dabei oder wieder 1 Jahr verschoben (also von letzter Saison)?
Original von Wahlencia
Hallo? Kann mir das keiner von euch sagen?
soweit ich weiss nicht aktuell... und liga kannstr auch keine spielen mit den NICHT-nhl teams... nur in die nhl ersetzen
Man kann keine DEL spielen???
Die Kader der DEL Teams sind veraltet, bei den Kaderupdates die es manchmal gibt wird die DEL nicht berücksichtig, lächerlich meiner Meinung nach. Davon abgesehen kann man keine Saison/Liga/Turnier mit DEL Teams spielen. Das ganze ist ne ziemliche Mogelpackung von EA, die sich mit den DEL Teams präsentieren aber am Ende kann man nur Freundschaftsspiele machen. Das einzige was man glaube ich machen kann, ist die NHL Teams durch DEL Teams in der richtigen Saison zu ersetzen, aber das bringts ja nicht da es zuwenig DEL Teams gibt.
Ich habe das Spiel selbst, abgesehen davon, was mich auch sehr ärgert, ist das Spiel top. Das Spiel ansich ist meiner Meinung nach das beste Sportspiel was es gibt. Grafik, Stimmung, Animationen, Steuerung - alles Bombe.
Ob es sich aber für dich lohnt @Wahlencia ist die Frage, da ich die Hoffnung habe im 2010er Teil ist vielleicht dann DEL Liga möglich, dann könntest du jetzt auch noch warten vor allem da du das Spiel selten unter 40 Euro bekommst.
Ja, ich werde auch warten. DEL hätte ich wahrscheinlich schwerpunktmäßig gezockt. Schade... Aber das gabs doch schonmal, oder? War das NHL 06 wo man ne DEl-Saison spielen konnte?
Die Kader waren da auch noch aus der Vorsaison aber das ist ja notfalls noch zu verschmerzen... Ich hoffe auf den 10er teil!
ich glaube, dass es eben um schwerpunkt nhl geht... und die anderen ligateams nur kleines gimmick für den kurzen freundschaftsspielspass is
denn wenn ne franchise startest, hast du ALLE spieler der europäischen teams im free agents roster... musst also nicht auf den liebling deiner del mannschaft verzichten oder zb die ganze mannschaft in der ahl auflaufen lassen
hat doch auch was, oder?
